Ga door naar hoofdinhoud
Disassembling Nokia 2366i Front Display
Wat je nodig hebt
  1. Disassembling Nokia 2366i Front Display, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia 2366i Front Display, Battery: stap 1, afbeelding 2 van 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Nokia 2366i Front Display: stap 2, afbeelding 1 van 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Nokia 2366i Front Display: stap 3, afbeelding 1 van 3 Disassembling Nokia 2366i Front Display: stap 3, afbeelding 2 van 3 Disassembling Nokia 2366i Front Display: stap 3, afbeelding 3 van 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Nokia 2366i Front Display, Front Cover: stap 4, afbeelding 1 van 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Nokia 2366i Front Display: stap 5, afbeelding 1 van 2 Disassembling Nokia 2366i Front Display: stap 5, afbeelding 2 van 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling Nokia 2366i Front Display: stap 6, afbeelding 1 van 2 Disassembling Nokia 2366i Front Display: stap 6, afbeelding 2 van 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling Nokia 2366i Front Display, Main Display: stap 7, afbeelding 1 van 2 Disassembling Nokia 2366i Front Display, Main Display: stap 7, afbeelding 2 van 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling Nokia 2366i Front Display: stap 8, afbeelding 1 van 2 Disassembling Nokia 2366i Front Display: stap 8, afbeelding 2 van 2
    • Using the spudger, disconnect the green display cable.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling Nokia 2366i Front Display: stap 9, afbeelding 1 van 3 Disassembling Nokia 2366i Front Display: stap 9, afbeelding 2 van 3 Disassembling Nokia 2366i Front Display: stap 9, afbeelding 3 van 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembling Nokia 2366i Front Display, Front Display: stap 10, afbeelding 1 van 3 Disassembling Nokia 2366i Front Display, Front Display: stap 10, afbeelding 2 van 3 Disassembling Nokia 2366i Front Display, Front Display: stap 10, afbeelding 3 van 3
    • Fold the metal casing back over.
    • Disconnect the orange front display data cable with the spudger.
    • Hold the phone so that the antenna is facing towards you.
    • Lift up and flip over the metal casing.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembling Nokia 2366i Front Display: stap 11, afbeelding 1 van 1
    • Using your fingers, remove the front display.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael Machado
337 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-14, Amido Winter 2011 Lid van Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 38
Altijd: 1,308
