Ga door naar hoofdinhoud
Disassembling Netatmo Outdoor Camera Main Unit
Wat je nodig hebt
    1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: stap 1, afbeelding 1 van 2 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: stap 1, afbeelding 2 van 2
      • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
      • The panel will lift up and can be removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Netatmo Outdoor Camera Main Unit: stap 2, afbeelding 1 van 2 Disassembling Netatmo Outdoor Camera Main Unit: stap 2, afbeelding 2 van 2
      • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
      • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
      • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Netatmo Outdoor Camera Main Unit: stap 3, afbeelding 1 van 2 Disassembling Netatmo Outdoor Camera Main Unit: stap 3, afbeelding 2 van 2
      • Remove the six 2.5mm hex screws using a long Allen key.
      • One screw has an earthing ring wire. Don't forget this when reassembling.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling Netatmo Outdoor Camera Main Unit: stap 4, afbeelding 1 van 2 Disassembling Netatmo Outdoor Camera Main Unit: stap 4, afbeelding 2 van 2
      • Separate the two pieces by pulling slightly on the lower module.
      • Pull the metal housing forward.
      • Pushing the light from the inside can help in removing the shell.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling Netatmo Outdoor Camera Main Unit: stap 5, afbeelding 1 van 1
      • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling Netatmo Outdoor Camera Main Unit: stap 6, afbeelding 1 van 2 Disassembling Netatmo Outdoor Camera Main Unit: stap 6, afbeelding 2 van 2
      • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
      • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
      • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
The Virtual Traveller
160 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 157
Altijd: 1,292
