Ga door naar hoofdinhoud
Disassembling Mouse Rapoo MT760 Pro
Wat je nodig hebt
  1. Disassembling Mouse Rapoo MT760 Pro, Remove Skates: stap 1, afbeelding 1 van 3 Disassembling Mouse Rapoo MT760 Pro, Remove Skates: stap 1, afbeelding 2 van 3 Disassembling Mouse Rapoo MT760 Pro, Remove Skates: stap 1, afbeelding 3 van 3
    • There are four screws hidden under the back two skates. You do not need to remove the front one. I used a razor blade to carefully lift the pads without touching the adhesive too much. If they get dirty, you may need to replace them.
    • There are two #1 Phillips screws under the main pad and two #0 Phillips screws under the thumb wing.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Mouse Rapoo MT760 Pro: stap 2, afbeelding 1 van 3 Disassembling Mouse Rapoo MT760 Pro: stap 2, afbeelding 2 van 3 Disassembling Mouse Rapoo MT760 Pro: stap 2, afbeelding 3 van 3
    • The back is now loose. Carefully start to pry it open, using a thin spudger or plastic card to the clips on the front.
    • There is one clip on near the USB-C port.
    • There are two clips just in front of the thumb. These are difficult to remove and require pulling the vertical silver piece out while slipping the bottom down.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Mouse Rapoo MT760 Pro: stap 3, afbeelding 1 van 3 Disassembling Mouse Rapoo MT760 Pro: stap 3, afbeelding 2 van 3 Disassembling Mouse Rapoo MT760 Pro: stap 3, afbeelding 3 van 3
    • Open the mouse carefully to avoid damaging the ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Be sure to keep your mouse skates clean or you may have to replace them.
Steven Williams
98 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 162
Altijd: 625
