Ga door naar hoofdinhoud
Disassembling Motorola i265 Rear Casing/Battery/SIM Card
Wat je nodig hebt
  1. Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: stap 1, afbeelding 1 van 2 Disassembling Motorola i265 Rear Casing/Battery/SIM Card, Rear Casing/Battery/SIM Card: stap 1, afbeelding 2 van 2
    • Press thumb against the top of the rear casing as shown and push down as you slide the casing off of the body.
    • You should hear a click as the latches on the casing disengage.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 2, afbeelding 1 van 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 2, afbeelding 2 van 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 2, afbeelding 3 van 3
    • To remove the battery, press thumb against the bottom edge of the battery and push towards the top of the phone.
    • Then, lift the bottom edge of the battery upwards out of the body. Gently pull the battery towards yourself, and out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 3, afbeelding 1 van 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 3, afbeelding 2 van 3 Disassembling Motorola i265 Rear Casing/Battery/SIM Card: stap 3, afbeelding 3 van 3
    • To remove SIM card, press thumb against tab marked “PUSH.”
    • While still pressing the PUSH tab, gently press spduger into the groove between the top of the SIM card and the body. Use spudger to slide SIM card toward the PUSH tab, so that when the spudger reaches the metal cover, the card itself is depressing the tab.
    • Press your thumb against the exposed section of the SIM card, and slide it towards the rear of the phone until it is completely free of the metal cover.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jonathan Uder
1 Reputatie
6 handleidingen geschreven
Cal Poly, Team 6-15, Maness Spring 2010 Lid van Cal Poly, Team 6-15, Maness Spring 2010
CPSU-MANESS-S10S6G15
4 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 37
Altijd: 2,888
