Ga door naar hoofdinhoud
Disassembling ModRetro Chromatic (Released Mid-2025)
Wat je nodig hebt
    1. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: stap 1, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: stap 1, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover and Batteries: stap 1, afbeelding 3 van 3
      • To remove the battery cover, push upward on the battery cover lock. The battery cover will pop open.
      • Lift the battery cover off and set aside.
      • Remove the batteries.
      • Always remove the batteries before working on your Chromatic!
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: stap 2, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: stap 2, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Back Shell: stap 2, afbeelding 3 van 3
      • Remove the back shell screws (x4) using a Tri-wing Y1 Screwdriver.
      • A Tri-wing Y1.5 will also work for all screws.
      • The screws near the top are a different length than the screws near the bottom of the shell.
      • Remove the back shell by lifting away from the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: stap 3, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: stap 3, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Menu Button: stap 3, afbeelding 3 van 3
      • Remove the menu button by lifting it off the post. It will remove with little to no resistance.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: stap 4, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: stap 4, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Tray: stap 4, afbeelding 3 van 3
      • Remove the battery tray screws (x3) using a Tri-wing Y1 Screwdriver.
      • Remove the battery tray connector.
      • It is helpful to press lightly against the PCB with your off hand while working the connector loose.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling ModRetro Chromatic (Released Mid-2025), PCB: stap 5, afbeelding 1 van 2 Disassembling ModRetro Chromatic (Released Mid-2025), PCB: stap 5, afbeelding 2 van 2
      • Carefully lift the LCD screen ribbon cable from the PCB.
      • Handle with care!
      • Carefully remove the PCB from the front shell.
      • Lifting at a slight angle will help clear the headphone jack on the bottom more easily. This is also important during re-assembly.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: stap 6, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: stap 6, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Speaker Module: stap 6, afbeelding 3 van 3
      • Remove the speaker module screw (x1) using a Tri-wing Y1 Screwdriver.
      • Carefully remove the speaker module from the front shell.
      Vraag FixBot
      Voeg opmerking toe
    7. Disassembling ModRetro Chromatic (Released Mid-2025), Light Pipe: stap 7, afbeelding 1 van 2 Disassembling ModRetro Chromatic (Released Mid-2025), Light Pipe: stap 7, afbeelding 2 van 2
      • Remove the light pipe screw (x1) using a Tri-wing Y1 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    8. Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: stap 8, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: stap 8, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Buttons and Membranes: stap 8, afbeelding 3 van 3
      • Remove the rubber button membranes (x3) from their pockets.
      • Remove the buttons and the D-pad from the shell with tweezers or by hand. If you flip the shell over, they will fall out freely.
      • The buttons will come out easily once the membranes are removed.
      • When re-attaching the rubber button membranes, be sure the positive features on the membranes seat securely into the pockets on the shell.
      Vraag FixBot
      Voeg opmerking toe
    9. Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: stap 9, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: stap 9, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), IR Window: stap 9, afbeelding 3 van 3
      • Carefully separate the IR window by gently wedging a plastic spudger between the IR window and the front shell.
      • Re-installing the IR window:
      • Note the side with the lip is inserted towards the front shell first.
      • Press in firmly until fully seated against the shell.
      • If the IR window fits loosely, the orientation is incorrect. The fit should be snug.
      Vraag FixBot
      Voeg opmerking toe
    10. Disassembling ModRetro Chromatic (Released Mid-2025), Power Switch: stap 10, afbeelding 1 van 1
      • Remove the power switch by lifting away from the front shell. It will remove with little resistance.
      • When re-assembling the power switch, make sure it is inserted in the OFF position.
      Vraag FixBot
      Voeg opmerking toe
    11. Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: stap 11, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: stap 11, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Cartridge Backer: stap 11, afbeelding 3 van 3
      • Remove the cartridge backer screws (x4) using a Tri-wing Y1 Screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    12. Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: stap 12, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: stap 12, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Latch Catch: stap 12, afbeelding 3 van 3
      • Remove the latch catch screws (x4) using a Tri-wing Y1 Screwdriver.
      • Gently push the latch up from the back using your finger.
      Vraag FixBot
      Voeg opmerking toe
    13. Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: stap 13, afbeelding 1 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: stap 13, afbeelding 2 van 3 Disassembling ModRetro Chromatic (Released Mid-2025), Battery Cover: stap 13, afbeelding 3 van 3
      • Remove the screws (x2) securing the latch cover using a Tri-wing Y1 Screwdriver.
      • Remove the door plate spring by fully depressing the battery cover lock. The spring should pop out.
      • Use a spudger if the spring does not fully dislodge.
      • Once the spring is removed, the battery cover lock can be removed without resistance through the underside of the battery cover.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
cj@modretro
259 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 49
Afgelopen 30 dagen: 238
Altijd: 2,967
