Ga door naar hoofdinhoud
Disassembling JBL Tour Pro 3 case
Wat je nodig hebt
  1. Disassembling JBL Tour Pro 3 case, Top ring: stap 1, afbeelding 1 van 3 Disassembling JBL Tour Pro 3 case, Top ring: stap 1, afbeelding 2 van 3 Disassembling JBL Tour Pro 3 case, Top ring: stap 1, afbeelding 3 van 3
    • Start by opening the case and removing the ring at the top by prying it off of the case
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling JBL Tour Pro 3 case, Touchscreen: stap 2, afbeelding 1 van 1
    • Now that the ring is off, heat up the touchscreen to loosen the adhesive behind it
    • Remove the touchscreen by using a prying pick to get in between the buds crevices and the touchscreen and pry it open just enough to press another pick in between the touchscreen and the case .
    • Use some isopropal alcohol to desolve the adhesive
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling JBL Tour Pro 3 case, insides: stap 3, afbeelding 1 van 1
    • Pry out the insides by using the prying picks in between the sides
    • Be careful for there is a cable attached to a daughter board which is screwed down at the bottom of the case.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling JBL Tour Pro 3 case, Daughter board: stap 4, afbeelding 1 van 2 Disassembling JBL Tour Pro 3 case, Daughter board: stap 4, afbeelding 2 van 2
    • Remove the 2 +0 size screws and pull out the daughter board
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Smokey
109 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 64
Altijd: 294
