Ga door naar hoofdinhoud
Disassembling IBM ThinkPad A30 Upper Case
Wat je nodig hebt
    1. Disassembling IBM ThinkPad A30 Upper Case, Battery: stap 1, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Upper Case, Battery: stap 1, afbeelding 2 van 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: stap 2, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: stap 2, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Upper Case, Hard Drive: stap 2, afbeelding 3 van 3
      • Remove the highlighted screw with a Phillips #1 screwdriver.
      • Pull the hard drive out.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling IBM ThinkPad A30 Upper Case, Upper Case: stap 3, afbeelding 1 van 1
      • Make sure the laptop is upside down and oriented in the direction shown.
      • Remove the six 16.7mm screws inside the circled holes.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling IBM ThinkPad A30 Upper Case: stap 4, afbeelding 1 van 1
      • Rotate the ThinkPad so that the hard drive bay is facing you.
      • Remove the black cover to reveal a 14.8mm screw.
      • Remove the uncovered screw with a Phillips #0 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling IBM ThinkPad A30 Upper Case: stap 5, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Upper Case: stap 5, afbeelding 2 van 2
      • Flip the ThinkPad over and open the LCD panel.
      • Pry apart the keyboard with a plastic opening tool or with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling IBM ThinkPad A30 Upper Case: stap 6, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 6, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 6, afbeelding 3 van 3
      • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
      • Lift the front end of the keyboard as shown.
      • Using your fingers, remove the black film cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling IBM ThinkPad A30 Upper Case: stap 7, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 7, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 7, afbeelding 3 van 3
      • Locate the connector attached to the motherboard.
      • Disconnect the ribbon cable by removing the connector.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling IBM ThinkPad A30 Upper Case: stap 8, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Upper Case: stap 8, afbeelding 2 van 2
      • Lift and remove the keyboard.
      • Remove the two 5.6mm screws.
      • Remove the 16.7mm screw.
      Vraag FixBot
      Voeg opmerking toe
    7. Disassembling IBM ThinkPad A30 Upper Case: stap 9, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 9, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Upper Case: stap 9, afbeelding 3 van 3
      • You will need to use a little force. Be wary of the tabs.
      • Pry off the upper case with your hands.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alan
380 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
116 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 40
Altijd: 2,653
