Ga door naar hoofdinhoud
Disassembling IBM ThinkPad A30 Speakers
Wat je nodig hebt
  1. Disassembling IBM ThinkPad A30 Speakers, Battery: stap 1, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers, Battery: stap 1, afbeelding 2 van 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling IBM ThinkPad A30 Speakers, Upper Case: stap 2, afbeelding 1 van 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling IBM ThinkPad A30 Speakers: stap 3, afbeelding 1 van 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling IBM ThinkPad A30 Speakers: stap 4, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 4, afbeelding 2 van 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling IBM ThinkPad A30 Speakers: stap 5, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 5, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 5, afbeelding 3 van 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling IBM ThinkPad A30 Speakers: stap 6, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 6, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 6, afbeelding 3 van 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling IBM ThinkPad A30 Speakers: stap 7, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 7, afbeelding 2 van 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling IBM ThinkPad A30 Speakers: stap 8, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 8, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 8, afbeelding 3 van 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling IBM ThinkPad A30 Speakers, Display Assembly: stap 9, afbeelding 1 van 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembling IBM ThinkPad A30 Speakers: stap 10, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 10, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 10, afbeelding 3 van 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembling IBM ThinkPad A30 Speakers: stap 11, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 11, afbeelding 2 van 2
    • Pull out the white tab connecting the LCD to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Disassembling IBM ThinkPad A30 Speakers: stap 12, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 12, afbeelding 2 van 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    Vraag FixBot
    Voeg opmerking toe
  13. Disassembling IBM ThinkPad A30 Speakers: stap 13, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 13, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 13, afbeelding 3 van 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    Vraag FixBot
    Voeg opmerking toe
  14. Disassembling IBM ThinkPad A30 Speakers, Fan: stap 14, afbeelding 1 van 1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  15. Disassembling IBM ThinkPad A30 Speakers: stap 15, afbeelding 1 van 1
    • Lift the heatsink bracket up.
    Vraag FixBot
    Voeg opmerking toe
  16. Disassembling IBM ThinkPad A30 Speakers: stap 16, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 16, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 16, afbeelding 3 van 3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    Vraag FixBot
    Voeg opmerking toe
  17. Disassembling IBM ThinkPad A30 Speakers, Speakers: stap 17, afbeelding 1 van 1
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
    Vraag FixBot
    Voeg opmerking toe
  18. Disassembling IBM ThinkPad A30 Speakers: stap 18, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 18, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 18, afbeelding 3 van 3
    • Turn the laptop over so the battery is facing you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
    Vraag FixBot
    Voeg opmerking toe
  19. Disassembling IBM ThinkPad A30 Speakers: stap 19, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 19, afbeelding 2 van 2
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    Vraag FixBot
    Voeg opmerking toe
  20. Disassembling IBM ThinkPad A30 Speakers: stap 20, afbeelding 1 van 1
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  21. Disassembling IBM ThinkPad A30 Speakers: stap 21, afbeelding 1 van 1
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
    Vraag FixBot
    Voeg opmerking toe
  22. Disassembling IBM ThinkPad A30 Speakers: stap 22, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 22, afbeelding 2 van 2
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
    Vraag FixBot
    Voeg opmerking toe
  23. Disassembling IBM ThinkPad A30 Speakers: stap 23, afbeelding 1 van 1
    • Locate the speakers on the bottom left and right of the ThinkPad A30.
    Vraag FixBot
    Voeg opmerking toe
  24. Disassembling IBM ThinkPad A30 Speakers: stap 24, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 24, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Speakers: stap 24, afbeelding 3 van 3
    • Remove the 5.6mm screws on each speaker.
    • Pull the right speaker out, making sure there is still slack in the wire.
    Vraag FixBot
    Voeg opmerking toe
  25. Disassembling IBM ThinkPad A30 Speakers: stap 25, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 25, afbeelding 2 van 2
    • Pull the blue tab that holds the speaker chip and pull the chip out.
    Vraag FixBot
    Voeg opmerking toe
  26. Disassembling IBM ThinkPad A30 Speakers: stap 26, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 26, afbeelding 2 van 2
    • Remove the wires from the white tabs by lifting the black wire casing.
    Vraag FixBot
    Voeg opmerking toe
  27. Disassembling IBM ThinkPad A30 Speakers: stap 27, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 27, afbeelding 2 van 2
    • Lift the left speaker out.
    Vraag FixBot
    Voeg opmerking toe
  28. Disassembling IBM ThinkPad A30 Speakers: stap 28, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Speakers: stap 28, afbeelding 2 van 2
    • Remove the speaker data and power cables by pulling them from the motherboard.
    • You have successfully removed the ThinkPad A30 speakers.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alan
380 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
26 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 47
Altijd: 2,663
