Ga door naar hoofdinhoud
Disassembling IBM ThinkPad A30 Motherboard
Wat je nodig hebt
  1. Disassembling IBM ThinkPad A30 Motherboard, Battery: stap 1, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard, Battery: stap 1, afbeelding 2 van 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: stap 2, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: stap 2, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard, Hard Drive: stap 2, afbeelding 3 van 3
    • Remove the highlighted screw with a Phillips #1 screwdriver.
    • Pull the hard drive out.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling IBM ThinkPad A30 Motherboard, CD Drive: stap 3, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: stap 3, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard, CD Drive: stap 3, afbeelding 3 van 3
    • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
    • Slide the switch to the right. A black plastic tab will pop out.
    • Pull the plastic tab to expose the CD drive.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling IBM ThinkPad A30 Motherboard: stap 4, afbeelding 1 van 1
    • Carefully pull the CD drive out from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: stap 5, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard, Floppy Disk Drive: stap 5, afbeelding 2 van 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling IBM ThinkPad A30 Motherboard: stap 6, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 6, afbeelding 2 van 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling IBM ThinkPad A30 Motherboard, Upper Case: stap 7, afbeelding 1 van 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling IBM ThinkPad A30 Motherboard: stap 8, afbeelding 1 van 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling IBM ThinkPad A30 Motherboard: stap 9, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 9, afbeelding 2 van 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembling IBM ThinkPad A30 Motherboard: stap 10, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 10, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 10, afbeelding 3 van 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembling IBM ThinkPad A30 Motherboard: stap 11, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 11, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 11, afbeelding 3 van 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    Vraag FixBot
    Voeg opmerking toe
  12. Disassembling IBM ThinkPad A30 Motherboard: stap 12, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 12, afbeelding 2 van 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    Vraag FixBot
    Voeg opmerking toe
  13. Disassembling IBM ThinkPad A30 Motherboard: stap 13, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 13, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 13, afbeelding 3 van 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    Vraag FixBot
    Voeg opmerking toe
  14. Disassembling IBM ThinkPad A30 Motherboard, Display Assembly: stap 14, afbeelding 1 van 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    Vraag FixBot
    Voeg opmerking toe
  15. Disassembling IBM ThinkPad A30 Motherboard: stap 15, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 15, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 15, afbeelding 3 van 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    Vraag FixBot
    Voeg opmerking toe
  16. Disassembling IBM ThinkPad A30 Motherboard: stap 16, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 16, afbeelding 2 van 2
    • Pull out the white tab connecting the LCD to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  17. Disassembling IBM ThinkPad A30 Motherboard: stap 17, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 17, afbeelding 2 van 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    Vraag FixBot
    Voeg opmerking toe
  18. Disassembling IBM ThinkPad A30 Motherboard: stap 18, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 18, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 18, afbeelding 3 van 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    Vraag FixBot
    Voeg opmerking toe
  19. Disassembling IBM ThinkPad A30 Motherboard, Fan: stap 19, afbeelding 1 van 1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    Vraag FixBot
    Voeg opmerking toe
  20. Disassembling IBM ThinkPad A30 Motherboard: stap 20, afbeelding 1 van 1
    • Lift the heatsink bracket up.
    Vraag FixBot
    Voeg opmerking toe
  21. Disassembling IBM ThinkPad A30 Motherboard: stap 21, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 21, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 21, afbeelding 3 van 3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    Vraag FixBot
    Voeg opmerking toe
  22. Disassembling IBM ThinkPad A30 Motherboard, CPU: stap 22, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard, CPU: stap 22, afbeelding 2 van 2
    • Use a flathead to turn the screw 180 degrees.
    • Remove the CPU by lifting it upwards.
    • If the CPU is reusable, place it in an antistatic bag and away from moisture.
    Vraag FixBot
    Voeg opmerking toe
  23. Disassembling IBM ThinkPad A30 Motherboard, Motherboard: stap 23, afbeelding 1 van 1
    • Locate the floppy drive bay.
    • Remove the four 5.6mm screws.
    • Remove the 16mm screw.
    Vraag FixBot
    Voeg opmerking toe
  24. Disassembling IBM ThinkPad A30 Motherboard: stap 24, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 24, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 Motherboard: stap 24, afbeelding 3 van 3
    • Turn the laptop over so that the battery is towards you.
    • Locate the modem and ethernet card bay.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
    Vraag FixBot
    Voeg opmerking toe
  25. Disassembling IBM ThinkPad A30 Motherboard: stap 25, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 25, afbeelding 2 van 2
    • Remove the four 9.1mm screws attached to the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    Vraag FixBot
    Voeg opmerking toe
  26. Disassembling IBM ThinkPad A30 Motherboard: stap 26, afbeelding 1 van 1
    • Locate the hard drive slot.
    • Remove the 8.8mm screw with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  27. Disassembling IBM ThinkPad A30 Motherboard: stap 27, afbeelding 1 van 1
    • Turn the laptop over again and orient it as shown.
    • Lift the left side of the floppy disk bay and and pull it out.
    • The black lever will pop out.
    Vraag FixBot
    Voeg opmerking toe
  28. Disassembling IBM ThinkPad A30 Motherboard: stap 28, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 28, afbeelding 2 van 2
    • Locate the CD Drive Bay
    • Remove the three 5.6mm screws.
    • Lift the right side and pull the CD drive bay out.
    Vraag FixBot
    Voeg opmerking toe
  29. Disassembling IBM ThinkPad A30 Motherboard: stap 29, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 29, afbeelding 2 van 2
    • Once the CD drive bay is removed, locate the speaker data and power cables.
    • Remove the cables from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  30. Disassembling IBM ThinkPad A30 Motherboard: stap 30, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 30, afbeelding 2 van 2
    • Locate the expansion bay.
    • Lift and remove the expansion bay.
    Vraag FixBot
    Voeg opmerking toe
  31. Disassembling IBM ThinkPad A30 Motherboard: stap 31, afbeelding 1 van 1
    • Rotate the laptop so that the back ports are facing you.
    Vraag FixBot
    Voeg opmerking toe
  32. Disassembling IBM ThinkPad A30 Motherboard: stap 32, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 32, afbeelding 2 van 2
    • Remove the three 5.8mm screws with a Phillips #0 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  33. Disassembling IBM ThinkPad A30 Motherboard: stap 33, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 33, afbeelding 2 van 2
    • Remove the six 11mm nuts with a wrench.
    • Pliers can be used, but are not recommended.
    Vraag FixBot
    Voeg opmerking toe
  34. Disassembling IBM ThinkPad A30 Motherboard: stap 34, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 34, afbeelding 2 van 2
    • Rotate the laptop to its original position.
    • Remove the 5.6mm screw located on the upper right corner of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  35. Disassembling IBM ThinkPad A30 Motherboard: stap 35, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Motherboard: stap 35, afbeelding 2 van 2
    • The wireless and bluetooth cards are connected to the motherboard!
    • Pull out the motherboard towards you carefully.
    • Place the motherboard somewhere dry and clean.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alan
380 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
26 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 42
Altijd: 9,083
