Ga door naar hoofdinhoud
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: stap 1, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: stap 1, afbeelding 2 van 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: stap 2, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: stap 2, afbeelding 2 van 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: stap 3, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: stap 3, afbeelding 2 van 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
162 Reputatie
7 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
26 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 3,217
