Ga door naar hoofdinhoud
Disassembling IBM ThinkPad A30 CD Drive
    1. Disassembling IBM ThinkPad A30 CD Drive, Battery: stap 1, afbeelding 1 van 2 Disassembling IBM ThinkPad A30 CD Drive, Battery: stap 1, afbeelding 2 van 2
      • Flip the ThinkPad over so that it is upside down.
      • Slide the highlighted tab to the left.
      • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling IBM ThinkPad A30 CD Drive, CD Drive: stap 2, afbeelding 1 van 3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: stap 2, afbeelding 2 van 3 Disassembling IBM ThinkPad A30 CD Drive, CD Drive: stap 2, afbeelding 3 van 3
      • Hold the laptop in the same orientation as the picture. Then, locate the switch immediately above and to the left of the drive.
      • Slide the switch to the right. A black plastic tab will pop out.
      • Pull the plastic tab to expose the CD drive.
      • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the CD drive, please check the corresponding entry in the troubleshooting page.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling IBM ThinkPad A30 CD Drive: stap 3, afbeelding 1 van 1
      • Carefully pull the CD drive out from the laptop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jessica
162 Reputatie
7 handleidingen geschreven
Cal Poly, Team 4-44, Amido Fall 2010 Lid van Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Leden
129 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 2,847
