Ga door naar hoofdinhoud
Disassembling Flip Video USB Port
Wat je nodig hebt
    1. Disassembling Flip Video USB Port, Outer Shell: stap 1, afbeelding 1 van 2 Disassembling Flip Video USB Port, Outer Shell: stap 1, afbeelding 2 van 2
      • Turn off the device and take the batteries out.
      • Remove metal sticker under the LCD screen with a spudger.
      • This may require a large force to pry off the glued sticker.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Flip Video USB Port: stap 2, afbeelding 1 van 1
      • Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Flip Video USB Port: stap 3, afbeelding 1 van 2 Disassembling Flip Video USB Port: stap 3, afbeelding 2 van 2
      • Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling Flip Video USB Port: stap 4, afbeelding 1 van 1
      • Open battery door. This can be done by gently depressing and sliding the battery down downward.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling Flip Video USB Port: stap 5, afbeelding 1 van 1
      • Use the spudger to separate outer shells.
      • The spudger must be inserted between the shell halves to pry the edges apart.
      • Slowly work around the outside to separate the halves.
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Flip Video USB Port, Circuit Board: stap 6, afbeelding 1 van 1
      • Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Flip Video USB Port: stap 7, afbeelding 1 van 1
      • Slowly lift the left side of the circuit board.
      • Do not attempt to remove the circuit board completely yet. It is still connected to the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Flip Video USB Port: stap 8, afbeelding 1 van 1
      • Disconnect the USB port cable from the back side of the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling Flip Video USB Port: stap 9, afbeelding 1 van 1
      • Slide out the battery contacts.
      • Battery contacts
      • Slot where battery contacts were located
      Vraag FixBot
      Voeg opmerking toe
    1. Disassembling Flip Video USB Port, USB Port: stap 10, afbeelding 1 van 1
      • Remove black 3mm screw that secures wire to outer shell with #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Flip Video USB Port: stap 11, afbeelding 1 van 1
      • Lift wire out of the outer shell slot.
      • The wire mount should stay attached to the wire.
      Vraag FixBot
      Voeg opmerking toe
    3. Disassembling Flip Video USB Port: stap 12, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use tweezers to remove the spring that holds the port door shut.
      • Make sure the spring is firmly grasped by the tweezers so that it does not shoot off of the case.
      Vraag FixBot
      Voeg opmerking toe
    4. Disassembling Flip Video USB Port: stap 13, afbeelding 1 van 1
      • Remove the 3 screws securing USB port cover to the outer case with the #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Disassembling Flip Video USB Port: stap 14, afbeelding 1 van 1
      • Remove the USB port cover.
      Vraag FixBot
      Voeg opmerking toe
    6. Disassembling Flip Video USB Port: stap 15, afbeelding 1 van 1
      • Remove the USB slider.
      Vraag FixBot
      Voeg opmerking toe
    7. Disassembling Flip Video USB Port: stap 16, afbeelding 1 van 1
      • Lift out the USB port slowly.
      • Since the hinge is spring loaded, be careful that no pieces fall out when the port is lifted.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elizabeth
100 Reputatie
6 handleidingen geschreven
Cal Poly, Team 26-21, Regan Spring 2010 Lid van Cal Poly, Team 26-21, Regan Spring 2010
CPSU-REGAN-S10S26G21
4 Leden
42 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 4,529
