Ga door naar hoofdinhoud
Disassembling Epson PPC650 Replacing Flash
Wat je nodig hebt
  1. Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 3 van 3
    • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
    • Remove the batteries from the battery compartment located on the underside of the camera.
    • Remove the SD card from the compartment located on the flat, left side of the camera.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Epson PPC650 Replacing Flash: stap 2, afbeelding 1 van 1
    • Remove the two screws on the rounded side of the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Epson PPC650 Replacing Flash: stap 3, afbeelding 1 van 2 Disassembling Epson PPC650 Replacing Flash: stap 3, afbeelding 2 van 2
    • Remove the three screws on the flat side of the camera.
    • All of the silver screws go into the side of the camera that is silver.
    • All of the black screws go into the side of the camera that is black.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Epson PPC650 Replacing Flash: stap 4, afbeelding 1 van 1
    • Remove the four screws from the bottom of the camera.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 3 van 3
    • Separate the front and the back pieces of the camera's plastic casing using a spudger.
    • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
    • Use minimal force so that the plastic casing does not break.
    • When separating the small silver siding, the indicator for the view/off/playback may fall out.
    • The plastic viewing window located on the top of the camera may also become lose and fall out.
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 3 van 3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling Epson PPC650 Replacing Flash: stap 7, afbeelding 1 van 1
    • Remove clear rubber band holding flash in line with wiring.
    Vraag FixBot
    Voeg opmerking toe
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    Vraag FixBot
    Voeg opmerking toe
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Xan Danes
134 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Buehl Spring 2013 Lid van Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 30
Altijd: 634
