Ga door naar hoofdinhoud
Disassembling Compaq Mini 110 Microphone
Wat je nodig hebt
  1. Disassembling Compaq Mini 110 Microphone, Battery: stap 1, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone, Battery: stap 1, afbeelding 2 van 2
    • Locate the battery and the battery tabs on the bottom of the Compaq Mini.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Compaq Mini 110 Microphone: stap 2, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone: stap 2, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone: stap 2, afbeelding 3 van 3
    • Push both tabs inward simultaneously and slide the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Compaq Mini 110 Microphone, RAM: stap 3, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone, RAM: stap 3, afbeelding 2 van 2
    • Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Compaq Mini 110 Microphone: stap 4, afbeelding 1 van 1
    • Push out the side tabs simultaneously and pull out the old RAM module.
    • When inserting a new RAM stick, be sure to evenly insert the gold pins in the same orientation that the old module was removed. While sliding the module in, press the side tabs in place.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Compaq Mini 110 Microphone, Keyboard: stap 5, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone, Keyboard: stap 5, afbeelding 2 van 2
    • Remove the rubber pads located on the corners of your Compaq Mini.
    • There may be junk underneath it. This is residue left from the glue that held on the rubber pad. Just scrape it away to find the screw.
    Vraag FixBot
    Voeg opmerking toe
  6. Disassembling Compaq Mini 110 Microphone: stap 6, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone: stap 6, afbeelding 2 van 2
    • Unscrew all the corner screws. There are four total, one under each rubber pad.
    Vraag FixBot
    Voeg opmerking toe
  7. Disassembling Compaq Mini 110 Microphone: stap 7, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone: stap 7, afbeelding 2 van 2
    • Unscrew the screw for the bottom case located in the RAM compartment.
    Vraag FixBot
    Voeg opmerking toe
  8. Disassembling Compaq Mini 110 Microphone: stap 8, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone: stap 8, afbeelding 2 van 2
    • Remove the three screws in the silver tabs at the back of the keyboard.
    • These are located at the back of the base under the screen.
    • Lift the keyboard away from the laptop.
    Vraag FixBot
    Voeg opmerking toe
  9. Disassembling Compaq Mini 110 Microphone, Hard Drive: stap 9, afbeelding 1 van 1
    • Remove the three screws holding the panel in place.
    Vraag FixBot
    Voeg opmerking toe
  10. Disassembling Compaq Mini 110 Microphone: stap 10, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone: stap 10, afbeelding 2 van 2
    • Pull up on the tab to remove the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  11. Disassembling Compaq Mini 110 Microphone, Top Cover: stap 11, afbeelding 1 van 1
    • Remove the eight screws that are from the plastic top cover.
    Vraag FixBot
    Voeg opmerking toe
  12. Disassembling Compaq Mini 110 Microphone: stap 12, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone: stap 12, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone: stap 12, afbeelding 3 van 3
    • Pry up the top plastic cover using a spudger.
    • These two tabs under the screen need to be pushed in with a spudger.
    Vraag FixBot
    Voeg opmerking toe
  13. Disassembling Compaq Mini 110 Microphone: stap 13, afbeelding 1 van 2 Disassembling Compaq Mini 110 Microphone: stap 13, afbeelding 2 van 2
    • Remove the cable by carefully pulling it up.
    • Be careful when lifting up the cover because the track pad is still attached.
    Vraag FixBot
    Voeg opmerking toe
  14. Disassembling Compaq Mini 110 Microphone, Display Assembly: stap 14, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone, Display Assembly: stap 14, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone, Display Assembly: stap 14, afbeelding 3 van 3
    • Remove the four screws that keep the bottom of the hinges attached to the base.
    Vraag FixBot
    Voeg opmerking toe
  15. Disassembling Compaq Mini 110 Microphone: stap 15, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone: stap 15, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone: stap 15, afbeelding 3 van 3
    • Pry off the top plastic cover of the display assembly.
    • The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
    • There is adhesive tape holding the cover on.
    Vraag FixBot
    Voeg opmerking toe
  16. Disassembling Compaq Mini 110 Microphone, Screen: stap 16, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone, Screen: stap 16, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone, Screen: stap 16, afbeelding 3 van 3
    • Remove the 4 screws keeping the screen on the plastic assembly.
    Vraag FixBot
    Voeg opmerking toe
  17. Disassembling Compaq Mini 110 Microphone: stap 17, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone: stap 17, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone: stap 17, afbeelding 3 van 3
    • Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
    • The last picture shows the metal connectors that attach it to the display assembly.
    Vraag FixBot
    Voeg opmerking toe
  18. Disassembling Compaq Mini 110 Microphone: stap 18, afbeelding 1 van 3 Disassembling Compaq Mini 110 Microphone: stap 18, afbeelding 2 van 3 Disassembling Compaq Mini 110 Microphone: stap 18, afbeelding 3 van 3
    • Detach the cable from the screen. It is connected under the foil flap.
    • The large wire on the back of the screen is for both the webcam and the microphone, as well as the screen.
    Vraag FixBot
    Voeg opmerking toe
  19. Disassembling Compaq Mini 110 Microphone, Microphone: stap 19, afbeelding 1 van 1
    • Just pull the little thing out. It's not attached on it's own.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
alea
1.429 Reputatie
14 handleidingen geschreven
Cal Poly, Team 22-2, Maness Fall 2010 Lid van Cal Poly, Team 22-2, Maness Fall 2010
CPSU-MANESS-F10S22G2
6 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 2,494
