Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Disassembling Canon EOS Rebel XS Front Cover
Wat je nodig hebt
  1. Disassembling Canon EOS Rebel XS Front Cover, Latch Side Cover: stap 1, afbeelding 1 van 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Disassembling Canon EOS Rebel XS Front Cover: stap 2, afbeelding 1 van 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Disassembling Canon EOS Rebel XS Front Cover, Disassembling Canon EOS Rebel XS Front Cover: stap 3, afbeelding 1 van 1
    • Remove three medium length screws from the bottom of the camera
  4. Disassembling Canon EOS Rebel XS Front Cover: stap 4, afbeelding 1 van 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
Conclusie
Daniel Bussone
1.251 Reputatie
11 handleidingen geschreven
Cal Poly, Team 3-41, Regan Winter 2011 Lid van Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Leden
21 handleidingen geschreven
2 opmerkingen
This should be labelled: Easy.
tjt263 - Antwoord
Okay, there are several steps missing.
tjt263 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 5,261
