Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Remove three medium length screws from the bottom of the camera
Remove the two medium length screws on the front panel of the camera above the lens mount.
Once you done, you may use the Spudger to panel from non-grip side.
