Ga door naar hoofdinhoud
Disassembling Apple IIc Cover
Wat je nodig hebt
  1. Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: stap 1, afbeelding 1 van 2 Disassembling Apple IIc Cover, Disassembling Apple IIc Cover: stap 1, afbeelding 2 van 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Apple IIc Cover: stap 2, afbeelding 1 van 2 Disassembling Apple IIc Cover: stap 2, afbeelding 2 van 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Apple IIc Cover: stap 3, afbeelding 1 van 2 Disassembling Apple IIc Cover: stap 3, afbeelding 2 van 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Apple IIc Cover: stap 4, afbeelding 1 van 2 Disassembling Apple IIc Cover: stap 4, afbeelding 2 van 2
    • Lift the handle straight up to remove.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
10 andere personen hebben deze handleiding voltooid.
Alexandria Weinberg
601 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-23, Maness Fall 2011 Lid van Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Leden
14 handleidingen geschreven
3Gids Commentaar
The //c is designed to be popped open. Remove the 6 screws as described. Flip the handle down and tip the //c 3-4 inches over a hard surface and let it drop. The handle will pop the rear catches off safely.
It looks and sounds scary but it's how Apple trained dealer techs to open the machine. There isn't anything in a //c that is shock sensitive.
Sean Fahey - Antwoord Deel
Just wanted you to know that your method is superior. I repair a lot of Apple IIC. Spudger method always results in broken plastic tabs. Your method never results in any damage.
Einar Offerdahl III - Antwoord Deel
Wow! Worked perfectly as described — and nothing broke. Hard to imagine I always had used steps 2, 3 (after removing the ports cover) and 4 in the past. Thanks, Sean!
mthmn1 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 75
Altijd: 11,357
