Ga door naar hoofdinhoud
Disassembling Ambient Weather AQIN Particulate Sensor
Wat je nodig hebt
    1. Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: stap 1, afbeelding 1 van 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: stap 1, afbeelding 2 van 3 Disassembling Ambient Weather AQIN Particulate Sensor, Particulate Sensor: stap 1, afbeelding 3 van 3
      • Looking at the sensor from the bottom, you can see the two tabs/prongs that hold the outer case together.
      • There is a fine cable attaching the internal components of the PM sensor. Be careful not to disrupt/break it.
      • The internal housing will now be exposed. You can use the two tabs/prongs on this porting to remove that portion of the case.
      • Next, you can remove the 4 small screws holding the internal components to the outer shell.
      Vraag FixBot
      Voeg opmerking toe
    2. Disassembling Ambient Weather AQIN Particulate Sensor: stap 2, afbeelding 1 van 2 Disassembling Ambient Weather AQIN Particulate Sensor: stap 2, afbeelding 2 van 2
      • Once the unit is disassembled, you can locate the internal motor of the unit.
      • Using compressed air, you may remove any debris that has become lodged on the intake shield of the motor.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Tim Elafros
493 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 202
