Ga door naar hoofdinhoud
Disassembling APEX AP-GS918 Screen
Wat je nodig hebt
  1. Disassembling APEX AP-GS918 Screen, Power/Volume Button: stap 1, afbeelding 1 van 3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: stap 1, afbeelding 2 van 3 Disassembling APEX AP-GS918 Screen, Power/Volume Button: stap 1, afbeelding 3 van 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. Disassembling APEX AP-GS918 Screen: stap 2, afbeelding 1 van 3 Disassembling APEX AP-GS918 Screen: stap 2, afbeelding 2 van 3 Disassembling APEX AP-GS918 Screen: stap 2, afbeelding 3 van 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. Disassembling APEX AP-GS918 Screen: stap 3, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. Disassembling APEX AP-GS918 Screen, Battery: stap 4, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen, Battery: stap 4, afbeelding 2 van 2
    • Begin removing the black tape covering the motherboard inside the tablet.
  5. Disassembling APEX AP-GS918 Screen: stap 5, afbeelding 1 van 1
    • You will need to desolder the two contact points that connect the battery to the mother board.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
  6. Disassembling APEX AP-GS918 Screen: stap 6, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen: stap 6, afbeelding 2 van 2
    • Using the black nylon spudger, get underneath the battery and begin prying it loose from the rest of the tablet.
    • The tape holding the battery to the tablet has a very strong hold so be prepared for resistance.
  7. Disassembling APEX AP-GS918 Screen, Screen: stap 7, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen, Screen: stap 7, afbeelding 2 van 2
    • The motherboard will need to be removed in order to access the screen.
    • To remove the motherboard you must first unscrew four 4.9mm Phillips #00 screws.
  8. Disassembling APEX AP-GS918 Screen: stap 8, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen: stap 8, afbeelding 2 van 2
    • To finish removing the motherboard you must release the two data cables holding the screen to it.
    • Use the black nylon spudger to lift the gray clips up 90° on the white connectors.
    • You can now remove the data cables from the slots and lift the motherboard out from the device.
  9. Disassembling APEX AP-GS918 Screen: stap 9, afbeelding 1 van 2 Disassembling APEX AP-GS918 Screen: stap 9, afbeelding 2 van 2
    • After removing the motherboard, use the black nylon spudger to pop the screen out of the housing holding it to the front of the screen case.
  10. Disassembling APEX AP-GS918 Screen: stap 10, afbeelding 1 van 1
    • Pull the thin plastic screen casing apart and you can remove the damaged screen.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Megan Lozicki
416 Reputatie
4 handleidingen geschreven
USF Tampa, Team 9-1, Leahy Winter 2015 Lid van USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Leden
9 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 812
