Ga door naar hoofdinhoud
Digital2 D2-861G Charging Port Replacement
Wat je nodig hebt
  1. Digital2 D2-861G Charging Port Replacement, Motherboards: stap 1, afbeelding 1 van 1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards.
  2. Digital2 D2-861G Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card.
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Charging Port Replacement: stap 3, afbeelding 1 van 3 Digital2 D2-861G Charging Port Replacement: stap 3, afbeelding 2 van 3 Digital2 D2-861G Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Locate the gold colored ZIF (Zero insertion force) connector and disconnect it from the motherboard.
    • To disconnect the ZIF connector, go under the black tab and lift up. Then pull the connector out.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently or using a spudger.
    • Disconnecting the bundled cable connector helps avoid short circuiting anything on the device.
  4. Digital2 D2-861G Charging Port Replacement: stap 4, afbeelding 1 van 3 Digital2 D2-861G Charging Port Replacement: stap 4, afbeelding 2 van 3 Digital2 D2-861G Charging Port Replacement: stap 4, afbeelding 3 van 3
    • Make sure to have your magnetic board to hold your screws.
    • Remove two 3.51mm screws that are located on the top corners with your Phillips #00 screwdriver.
    • Next, unplug the ZIF connector by going under the black tab and simply lift up.
    • Slide the connector out with the pointed side of the spudger.
  5. Digital2 D2-861G Charging Port Replacement: stap 5, afbeelding 1 van 3 Digital2 D2-861G Charging Port Replacement: stap 5, afbeelding 2 van 3 Digital2 D2-861G Charging Port Replacement: stap 5, afbeelding 3 van 3
    • This step is optional if you want to remove the metal casing.
    • Insert the pointed side of the spudger in the corner and gently lift.
    • Once one side is lifted, use your fingers and with little force, lift up to remove the case.
  6. Digital2 D2-861G Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Use little force or else you risk breaking the motherboard.
    • Watch out for the ZIF connector!
    • There is a white clip holding the motherboard.
    • To remove the motherboard, grab the component on the top left and gently lift while pushing or pulling to the right.
  7. Digital2 D2-861G Charging Port Replacement, Charging Port: stap 7, afbeelding 1 van 1
    • Refer to iFixit's guide on how to Solder Hoe moet je (de-)solderen?
    • To replace the charging port, you can either replace the motherboard or desolder the port.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 246
