Ga door naar hoofdinhoud
Digitac Jazz Ultratab C725 Motherboard Replacement
Wat je nodig hebt
  1. Digitac Jazz Ultratab C725 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Locate the four 3.5 mm Phillips head screws holding the silver back plate and the screen together. There are 2 screws on the top and another 2 screws on the bottom.
    • Using the Phillips #00 Screwdriver, remove all 4 screws.
    • Remove the screws with the least amount of force possible to avoid any damage to the threads. If thread damage occurs, screw removal will be much more difficult or may even become impossible.
  2. Digitac Jazz Ultratab C725 Motherboard Replacement: stap 2, afbeelding 1 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 2, afbeelding 2 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Flip your device so that the long side without the buttons is facing you.
    • Insert the Plastic Opening Tool between the silver back plate and the screen about 1 inch from corner of the device on either side.
    • Jimmy the Plastic Opening Tool until the screen unsnaps from the back plate.
    • Work your way down the edge of the device, popping out all locations where the screen snaps into the silver back plate.
    • Go around the corners with the Plastic Opening Tool and unsnap additional snap-in locations as necessary.
    • Once the screen is loose, pull it towards you then lift it off to prevent damage to the buttons on the other side of the device.
  3. Digitac Jazz Ultratab C725 Motherboard Replacement: stap 3, afbeelding 1 van 2 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Take a Soldering Iron and melt the solder connecting to battery wires to the motherboard.
    • There are two wires, black and red.
    • Next, use the soldering iron to melt the connection for the speaker.
    • The speaker has two wires as well, red and black.
    • Finally, use the soldering iron to melt the connection for the antenna wire.
    • The antenna wire is a the single grey wire.
    • Once the solder is melted, pull the wires out.
  4. Digitac Jazz Ultratab C725 Motherboard Replacement: stap 4, afbeelding 1 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 4, afbeelding 2 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Locate the 3 white clips on the motherboard that hold the data cables.
    • Using the Spudger, pry the black clips up to a 90 degree angle.
    • Once the clip is up, pull the data cables out.
    • Repeat this for all 3 clips.
  5. Digitac Jazz Ultratab C725 Motherboard Replacement: stap 5, afbeelding 1 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 5, afbeelding 2 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Locate the two 4.0 mm Phillips head screws that are holding the motherboard. There is one on the top and one on the bottom of the motherboard.
    • Using the Phillips #00 Screwdriver, remove both screws.
  6. Digitac Jazz Ultratab C725 Motherboard Replacement: stap 6, afbeelding 1 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 6, afbeelding 2 van 3 Digitac Jazz Ultratab C725 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • The motherboard should now be loose. Pull it off of the tablet carefully.
Conclusie
Savannah Brazzeal
300 Reputatie
2 handleidingen geschreven
USF Tampa, Team 11-6, Blackwell Winter 2015 Lid van USF Tampa, Team 11-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G6
2 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 227
