Inleiding
This guide will allow you to access the inside parts of the Digiland DL1168A through means of removing the rear case. By removing the rear case you can replace the rear case as well as other parts inside the tablet. You will need to desolder the connections on the motherboard to remove the back panel.
Wat je nodig hebt
Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
