Ga door naar hoofdinhoud
Digiland DL1168A Rear Case Replacement
Wat je nodig hebt
  1. Digiland DL1168A Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Rear Case Replacement: stap 2, afbeelding 1 van 2 Digiland DL1168A Rear Case Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Rear Case Replacement: stap 3, afbeelding 1 van 2 Digiland DL1168A Rear Case Replacement: stap 3, afbeelding 2 van 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 115
