Ga door naar hoofdinhoud
Digiland DL1168A Motherboard Replacement
Wat je nodig hebt
  1. Digiland DL1168A Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Motherboard Replacement: stap 2, afbeelding 1 van 2 Digiland DL1168A Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Motherboard Replacement: stap 3, afbeelding 1 van 2 Digiland DL1168A Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 2 Digiland DL1168A Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a pair of tweezers, carefully lift the three zero insertion force connectors (ZIF) attached to the motherboard.
  5. Digiland DL1168A Motherboard Replacement: stap 5, afbeelding 1 van 2 Digiland DL1168A Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Using the soldering iron, desolder all eight wires connected to the motherboard.
    • Removing the red wire then the black wire (2 wires).
    • Desolder the three wires and remove them.
    • Remove the single grey wire.
    • Remove the yellow and red twisted wires and black and red twisted wires connected to the speakers.
  6. Digiland DL1168A Motherboard Replacement: stap 6, afbeelding 1 van 2 Digiland DL1168A Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the four 4mm Phillips #00 screws attached to the motherboard.
  7. Digiland DL1168A Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently lift and remove the motherboard using the iFixit opening tool.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 111
