Ga door naar hoofdinhoud
Digiland DL1168A Front/Rear Camera Replacement
Wat je nodig hebt
  1. Digiland DL1168A Front/Rear Camera Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
    Vraag FixBot
    Voeg opmerking toe
  2. Digiland DL1168A Front/Rear Camera Replacement: stap 2, afbeelding 1 van 2 Digiland DL1168A Front/Rear Camera Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Digiland DL1168A Front/Rear Camera Replacement: stap 3, afbeelding 1 van 2 Digiland DL1168A Front/Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Digiland DL1168A Front/Rear Camera Replacement, Front/Rear Camera: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to remove the cover that keeps the camera lens in place.
    Vraag FixBot
    Voeg opmerking toe
  5. Digiland DL1168A Front/Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • Use tweezers to gently begin to lift the back piece off.
    • Lift gently because the lens is connected to the back piece by a small cord.
    Vraag FixBot
    Voeg opmerking toe
  6. Digiland DL1168A Front/Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • After lifting gently both the lens and the back piece will be removed.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Payton Boshears
97 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 336
