Ga door naar hoofdinhoud
Diagnosing and Erasing Hard Drives
Wat je nodig hebt
  1. Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: stap 1, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: stap 1, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, Mounting the hard drive for testing: stap 1, afbeelding 3 van 3
    • If the drive is not installed in a PC, a USB adapter can be used. If you are using an M.2 SSD (NVMe or SATA) you will need a different enclosure than shown in these guide photos.
    • If the hard drive is not installed and you do not have a USB adapter, it can be plugged into a motherboard.
  2. Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: stap 2, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: stap 2, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Ubuntu) POH/POC Check: stap 2, afbeelding 3 van 3
    • While high hours are not an indication of failure, the odds of a failure are much higher.
    • GSmartControl can be used in Ubuntu if you cannot read the output from Disks.
    • Boot your system into a live Ubuntu session. Locate the Disks application and select the suspicious hard drive.
    • From the drop-down menu, select SMART Data and Self Tests. This will pull up the SMART data.
    • Locate the following SMART attributes: Power On Hours and Power Cycle Count.
  3. Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: stap 3, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: stap 3, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Ubuntu) Reallocated sectors and SMART testing: stap 3, afbeelding 3 van 3
    • If the Reallocated Sector Count is highlighted with a high count, REPLACE THE DRIVE; they are prone to failure and unexpected capacity loss! While SMART Extended is better, a quick test may be sufficient.
    • Locate the following SMART attributes: Reallocated sector count; Current pending sector count.
    • To run a SMART Extended Self-Test, left click Start Self-Test. Select Extended from the drop-down menu.
  4. Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: stap 4, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: stap 4, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) POH/POC check: stap 4, afbeelding 3 van 3
    • Select Disks from the desktop to open GSmartControl.
    • Select the hard disk you want to test. Click Attributes to read the SMART data.
    • Locate the following attributes: Power On Time and Power Cycle Count.
  5. Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: stap 5, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: stap 5, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Reallocated sectors and SMART testing: stap 5, afbeelding 3 van 3
    • In the Attributes tab, locate the following SMART attributes: Reallocated Sector Count; Reallocation Event Count; Current Pending Sector Count.
    • To test the drive, select Perform Tests. Click Test type: and select Extended Self-Test.
  6. Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: stap 6, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: stap 6, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Error log check: stap 6, afbeelding 3 van 3
    • Use the error log and SMART data together to diagnose drive problems.
    • Check the error log for drive errors. Click the Error log tab, and review the logs.
    • In the Error log, review the available errors. Read these logs if any are found.
  7. Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: stap 7, afbeelding 1 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: stap 7, afbeelding 2 van 3 Diagnosing and Erasing Hard Drives, (Parted Magic) Erasing hard drives: stap 7, afbeelding 3 van 3
    • When possible, avoid sector-wiping SSDs. This will reduce the drive liftetime and can be drastic on older 75TBW SSDs.
    • Your erase options will be limited to the Security Set options supported in the drive firmware.
    • Drives without ATA Secure Erase will need to be erased externally. Select External and choose Nwipe. Run the DoD Short command (3 wipes+drive blanking).
    • If your drive has a buggy ATA Secure Erase implementation, choose External and erase the drive with Nwipe. SSDs should only be erased with the Secure Erase command.
    • For NVMe SSDs, the best option is to use NVMe Secure Erase.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Nick
88.851 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.535 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 1,775
