Ga door naar hoofdinhoud
Desktop PC GPU Replacement
Wat je nodig hebt
  1. Desktop PC GPU Replacement, Create an Anti-Static Work Area: stap 1, afbeelding 1 van 1
    • Minimize exposure to items that can charge up and produce static electricity.
    • Use an anti-static wrist band.
    Vraag FixBot
    Voeg opmerking toe
  2. Desktop PC GPU Replacement, Turn Off Computer: stap 2, afbeelding 1 van 1
    • Power off PC via Windows.
    • Switch off Power Supply
    Vraag FixBot
    Voeg opmerking toe
  3. Desktop PC GPU Replacement, Unscrew Case Side Panel: stap 3, afbeelding 1 van 2 Desktop PC GPU Replacement, Unscrew Case Side Panel: stap 3, afbeelding 2 van 2
    • Put screws where you wont lose them
    Vraag FixBot
    Voeg opmerking toe
  4. Desktop PC GPU Replacement, Unplug Power Connector to GPU: stap 4, afbeelding 1 van 1
    • Be gentle to not pull with to much force when removing power cables.
    Vraag FixBot
    Voeg opmerking toe
  5. Desktop PC GPU Replacement, Flip GPU Lock on Motherboard: stap 5, afbeelding 1 van 1
    • Try not to touch other components.
    Vraag FixBot
    Voeg opmerking toe
    • Gently pull the card out of the slot.
    Vraag FixBot
    Voeg opmerking toe
  6. Desktop PC GPU Replacement, Insert New GPU: stap 7, afbeelding 1 van 1
    • Verify that the notch in the connector matches the motherboard before sliding in.
    • Carefully slide in GPU until you hear a click on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Desktop PC GPU Replacement, Connect Power Cables: stap 8, afbeelding 1 van 1
    • Insert wisdom here.
    Vraag FixBot
    Voeg opmerking toe
  8. Desktop PC GPU Replacement, Re-Attach Side Panel: stap 9, afbeelding 1 van 1
    • Use same screws from step 2.
    Vraag FixBot
    Voeg opmerking toe
    • Flip power supply switch back to on.
    • Plug in PC and turn on.
    • If PC does not post go back through the steps to see if you missed something.
    Vraag FixBot
    Voeg opmerking toe
    • Go to manufacturer's website or use the CD that came with the card to download the latest drivers for the GPU to ensure better stability of GPU.
    Vraag FixBot
    Voeg opmerking toe
    • Enjoy your new GPU.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joseph Thompson
295 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 103
Altijd: 2,102
