Ga door naar hoofdinhoud
Dell XPS 720 H2C Graphics Card Replacement
    1. Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 1 van 2 Dell XPS 720 H2C Graphics Card Replacement, Removing Dell XPS 720 H2C Cover Panel: stap 1, afbeelding 2 van 2
      • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: stap 2, afbeelding 1 van 2 Dell XPS 720 H2C Graphics Card Replacement, Graphics Card: stap 2, afbeelding 2 van 2
      • Locate the graphics card near the bottom-right area of the computer, just below the XPS processor cooler.
      • Before entering into the "guts" of the computer, make sure you have the computer powered off and unplugged. Following that, you will want to unplug any video cables, including DVI and VGA cables, that are connected to the graphics port on the back panel of the computer.
      • Some DVI cables may need to be unscrewed. This can simply be done by hand.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 720 H2C Graphics Card Replacement: stap 3, afbeelding 1 van 3 Dell XPS 720 H2C Graphics Card Replacement: stap 3, afbeelding 2 van 3 Dell XPS 720 H2C Graphics Card Replacement: stap 3, afbeelding 3 van 3
      • Remove the support underneath the processor cooler by pressing down on the latch at the top of the support and pulling the support towards you.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell XPS 720 H2C Graphics Card Replacement: stap 4, afbeelding 1 van 1
      • Continue by pressing down on blue tab restraining on the graphics card. In the picture the graphics card is shown to have the fourth blue clip from the top holding it in.
      • Pressing down on this clip will enable you to remove the graphics card from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell XPS 720 H2C Graphics Card Replacement: stap 5, afbeelding 1 van 1
      • Unplug the cable labeled "P3" on the left side of the graphics card. Be sure to push the plastic pin all the way down and pull firmly.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell XPS 720 H2C Graphics Card Replacement: stap 6, afbeelding 1 van 1
      • Grab the graphics card with two hands and pull directly outward. The card may not come out smoothly. If this is the case, apply firm and even pressure with both hands.
      • If you are reseating the graphics card, this is the time to clean it and make sure dust has been removed from the socket the graphics card sits in.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Colyn Dickson
110 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-16, Maness Spring 2013 Lid van Cal Poly, Team 4-16, Maness Spring 2013
CPSU-MANESS-S13S4G16
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 31
Altijd: 3,974
