Ga door naar hoofdinhoud
Dell XPS 18 Touch Control Board Replacement
Wat je nodig hebt
    1. Dell XPS 18 Touch Control Board Replacement, Back Cover: stap 1, afbeelding 1 van 1
      • Turn the device on its screen.
      • Remove the ten 4mm screws using a T8 Torx screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 18 Touch Control Board Replacement: stap 2, afbeelding 1 van 1
      • Gently flip out support feet located near the bottom of device.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell XPS 18 Touch Control Board Replacement: stap 3, afbeelding 1 van 1
      • Gently lift the back cover off the device. The back cover should come off easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell XPS 18 Touch Control Board Replacement, Internal Cover: stap 4, afbeelding 1 van 1
      • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 18 Touch Control Board Replacement: stap 5, afbeelding 1 van 2 Dell XPS 18 Touch Control Board Replacement: stap 5, afbeelding 2 van 2
      • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell XPS 18 Touch Control Board Replacement: stap 6, afbeelding 1 van 2 Dell XPS 18 Touch Control Board Replacement: stap 6, afbeelding 2 van 2
      • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
      • Remove the internal cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell XPS 18 Touch Control Board Replacement, Touch Control Board: stap 7, afbeelding 1 van 2 Dell XPS 18 Touch Control Board Replacement, Touch Control Board: stap 7, afbeelding 2 van 2
      • Disconnect the black camera cable and pull it back to prevent future hassle.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 18 Touch Control Board Replacement: stap 8, afbeelding 1 van 2 Dell XPS 18 Touch Control Board Replacement: stap 8, afbeelding 2 van 2
      • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
      • Disconnect the silver and blue touch control board cable.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell XPS 18 Touch Control Board Replacement: stap 9, afbeelding 1 van 2 Dell XPS 18 Touch Control Board Replacement: stap 9, afbeelding 2 van 2
      • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
      • Remove the touch control board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Austin Weir
1.308 Reputatie
8 handleidingen geschreven
Cal Poly, Team 6-29, Amido Winter 2015 Lid van Cal Poly, Team 6-29, Amido Winter 2015
CPSU-AMIDO-W15S6G29
4 Leden
16 handleidingen geschreven
2Gids Commentaar
It worked perfectly. Thank you.
Kenneth Macdonald - Antwoord Deel
Which of Torx screwdrivers is used in step 1? As I can see, it is T8, but right above the Introduction section it is stated it is Torx T9...
Евгений Громов - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 2,319
