Ga door naar hoofdinhoud
Dell XPS 15 9550 RAM Replacement
Wat je nodig hebt
    1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: stap 1, afbeelding 1 van 1
      • Turn the laptop upside down.
      • Make sure the laptop is turned off.
      • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 15 9550 RAM Replacement: stap 2, afbeelding 1 van 2 Dell XPS 15 9550 RAM Replacement: stap 2, afbeelding 2 van 2
      • Open up the information panel door (on the middle of the back side).
      • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell XPS 15 9550 RAM Replacement: stap 3, afbeelding 1 van 3 Dell XPS 15 9550 RAM Replacement: stap 3, afbeelding 2 van 3 Dell XPS 15 9550 RAM Replacement: stap 3, afbeelding 3 van 3
      • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
      • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell XPS 15 9550 RAM Replacement, RAM: stap 4, afbeelding 1 van 2 Dell XPS 15 9550 RAM Replacement, RAM: stap 4, afbeelding 2 van 2
      • There are 2 separate RAM sticks.
      • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
      • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell XPS 15 9550 RAM Replacement: stap 5, afbeelding 1 van 2 Dell XPS 15 9550 RAM Replacement: stap 5, afbeelding 2 van 2
      • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
jbaseballin2
123 Reputatie
1 Handleiding geschreven
UW Stout, Team S6-G1, Ogden Fall 2018 Lid van UW Stout, Team S6-G1, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G1
4 Leden
23 handleidingen geschreven
1Gids Commentaar
What type ram do you replace it with? Could you post a link?
twrfan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 38
Altijd: 9,716
