Ga door naar hoofdinhoud
Dell XPS 15 9510 RAM Replacement
Wat je nodig hebt
  1. Dell XPS 15 9510 RAM Replacement, Rear Panel: stap 1, afbeelding 1 van 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 RAM Replacement: stap 2, afbeelding 1 van 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 RAM Replacement: stap 3, afbeelding 1 van 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Using both hands, pull the clips that hold the RAM in place.
  5. Dell XPS 15 9510 RAM Replacement: stap 5, afbeelding 1 van 2 Dell XPS 15 9510 RAM Replacement: stap 5, afbeelding 2 van 2
    • Gently, with both hands, pull the RAM up at a 45º angle and take out the RAM.
    • Repeat the same process with the other RAM.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bethany Wright
421 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-1, Harley Summer 2023 Lid van IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 46
Altijd: 596
