Ga door naar hoofdinhoud
Dell XPS 14 Fan Replacement
Wat je nodig hebt
  1. Dell XPS 14 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Fan Replacement: stap 2, afbeelding 1 van 3 Dell XPS 14 Fan Replacement: stap 2, afbeelding 2 van 3 Dell XPS 14 Fan Replacement: stap 2, afbeelding 3 van 3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Fan Replacement: stap 3, afbeelding 1 van 2 Dell XPS 14 Fan Replacement: stap 3, afbeelding 2 van 2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Fan Replacement: stap 4, afbeelding 1 van 3 Dell XPS 14 Fan Replacement: stap 4, afbeelding 2 van 3 Dell XPS 14 Fan Replacement: stap 4, afbeelding 3 van 3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Fan Replacement, Speaker: stap 5, afbeelding 1 van 2 Dell XPS 14 Fan Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Fan Replacement: stap 6, afbeelding 1 van 2 Dell XPS 14 Fan Replacement: stap 6, afbeelding 2 van 2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 Fan Replacement, Battery: stap 7, afbeelding 1 van 1
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 Fan Replacement: stap 8, afbeelding 1 van 3 Dell XPS 14 Fan Replacement: stap 8, afbeelding 2 van 3 Dell XPS 14 Fan Replacement: stap 8, afbeelding 3 van 3
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 Fan Replacement, Fan: stap 9, afbeelding 1 van 1
    • Remove the two 2 mm screws from the fan using a Phillips #0 screwdriver.
  10. Dell XPS 14 Fan Replacement: stap 10, afbeelding 1 van 2 Dell XPS 14 Fan Replacement: stap 10, afbeelding 2 van 2
    • Use two thumbs to pop out the plug that connects the fan to the laptop.
    • Remove the fan from the laptop.
Conclusie
Gabriella Monico
457 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-3, Botvin Spring 2022 Lid van UMass Dartmouth, Team 1-3, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G3
3 Leden
1Gids Commentaar
Thanks for sharing! One question: Isn't it sufficient to just remove the plug of the battery?
Thomas - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 486
