Ga door naar hoofdinhoud
Dell XPS 13 7390 Battery Replacement
Wat je nodig hebt
  1. Dell XPS 13 7390 Battery Replacement, Removing the base cover: stap 1, afbeelding 1 van 3 Dell XPS 13 7390 Battery Replacement, Removing the base cover: stap 1, afbeelding 2 van 3 Dell XPS 13 7390 Battery Replacement, Removing the base cover: stap 1, afbeelding 3 van 3
    • Remove the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
    • With the computer face-down, open the computer at an angle.
    • Using a plastic scribe, pry the base cover from the palm-rest assembly, starting at the front left and right corners.
    • Moving the base cover from left to right, release the clips securing the base cover to the palm-rest assembly.
    • Lift the base cover from the palm-rest assembly.
  2. Dell XPS 13 7390 Battery Replacement, Remove the old battery: stap 2, afbeelding 1 van 2 Dell XPS 13 7390 Battery Replacement, Remove the old battery: stap 2, afbeelding 2 van 2
    • Ensure that the battery cable is disconnected from the system board.
    • Remove the four screws (M2x2) that secure the battery to the palm-rest assembly
    • Remove the screw (M1.6x4) that secures the battery to the palm-rest assembly.
    • Lift the battery off the palm-rest assembly.
    • Turn the computer over, open the display, and press the power button for about 5 seconds to ground the computer.
  3. Dell XPS 13 7390 Battery Replacement, Insert the new battery: stap 3, afbeelding 1 van 1
    • Align the screw holes on the battery with the screw holes on the palm-rest assembly.
    • Replace the four screws (M2x2) that secure the battery to the palm-rest assembly.
    • Replace the screw (M1.6x4) that secures the battery to the palm-rest assembly
  4. Dell XPS 13 7390 Battery Replacement, Reattach base case: stap 4, afbeelding 1 van 2 Dell XPS 13 7390 Battery Replacement, Reattach base case: stap 4, afbeelding 2 van 2
    • Align the screw holes on the base cover with the screw holes on the palm-rest assembly and slide in the base cover into place.
    • Replace the eight screws (M2x3, Torx) that secure the base cover to the palm-rest assembly
Conclusie
Congratulations, you’re all done!
15 andere personen hebben deze handleiding voltooid.
Max Kletskov
40.880 Reputatie
16 handleidingen geschreven
The Home Depot Lid van The Home Depot
Community
18.126 Leden
140 handleidingen geschreven
3 opmerkingen
I have an xps 13 7390 and when I perform step 1 - prying open the base cover - the computer turns on. I searched the internet for how to configure my PC to not automatically power on when the lid opens (even when it's only opened 1/4 of the way it tries to turn on) and my BIOS does not seem to have a Power On - Lid Open on/off option. Any suggestions? Thanks.
Uncle - Antwoord
UPDATE - My XPS 7390 does, in fact, have a LID Power on/off option through the F2 Function. This gets you into BIOS and it was all the way at the bottom of the Power Management option. Apologies.
Uncle - Antwoord
This guide is better and more accurate than Dell’s website. Just replaced the battery DHGH8 (4-cell 52 Wh, 7.6 V) in my XPS 7390 with no problems.
Jacob Wickham - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 138
Afgelopen 30 dagen: 645
Altijd: 18,069
