Ga door naar hoofdinhoud
Dell Vostro V130 Memory Module Replacement
Wat je nodig hebt
    1. Dell Vostro V130 Memory Module Replacement, Remove the Screws: stap 1, afbeelding 1 van 1
      • Remove the screws that secure the base cover to the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro V130 Memory Module Replacement, Removing the Base Cover: stap 2, afbeelding 1 van 1
      • Slide the base cover towards the front of the computer. Lift it up and away from the computer.
      • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro V130 Memory Module Replacement, Disconnecting the Battery: stap 3, afbeelding 1 van 1
      • Lift the black cable-release clip to release the battery cable from the connector on the system board and disconnect the battery cable.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro V130 Memory Module Replacement, Remove Battery Screws: stap 4, afbeelding 1 van 1
      • Remove the screws that secure the battery to the computer.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Vostro V130 Memory Module Replacement, Lift the Battery: stap 5, afbeelding 1 van 1
      • Lift the battery up and away from the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro V130 Memory Module Replacement, LED Cover: stap 6, afbeelding 1 van 1
      • Starting on the right side of the system, use a plastic scribe to pry up the LED cover from the computer.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro V130 Memory Module Replacement, Removing the LED Cover: stap 7, afbeelding 1 van 1
      • Pull the LED cover toward the keyboard and remove it from the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro V130 Memory Module Replacement, Memory Module: stap 8, afbeelding 1 van 1
      • Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro V130 Memory Module Replacement: stap 9, afbeelding 1 van 1
      • Remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
Johnathan Hammond
46.185 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
12.124 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 634
