Wat je nodig hebt
Remove the screws that secure the access panel to the computer [1].
Lift the access panel partially at a 45–degree angle [2].
Pry the securing clips away from the memory module until it pops up
Remove the memory module from its socket on the system board.
If this is all you are doing Follow Step In Reverse if not Go to Next Step.
