Ga door naar hoofdinhoud
Dell Vostro 3500 Memory Module Replacement
Wat je nodig hebt
    1. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Latch: stap 1, afbeelding 1 van 1
      • Flip the computer over.
      • Slide the battery release latch to the unlock position.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro 3500 Memory Module Replacement, Sliding the Battery Release Latch: stap 2, afbeelding 1 van 1
      • Slide the other battery release latch to the unlock position.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Vostro 3500 Memory Module Replacement, Removing the Battery: stap 3, afbeelding 1 van 1
      • Slide the battery and remove it from the computer.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro 3500 Memory Module Replacement, Remove the Screws: stap 4, afbeelding 1 van 1
      • Turn the laptop over and remove two screws securing the service cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro 3500 Memory Module Replacement, Removing the Base Cover: stap 5, afbeelding 1 van 1
      • Prise up the service cover and remove it from the computer. Clips along the edges can be snapped open except for those on the left hand edge (as shown in the photo) which have to be disengaged after all the others by romoving the cover in the direction shown.
      • On resassembly, insert the clips on the left hand edge then snap all te others home by applying firm pressure along the other edges of the cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro 3500 Memory Module Replacement, Releasing the Memory Module: stap 6, afbeelding 1 van 1
      • Push apart the memory retention clips to release the memory module.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Vostro 3500 Memory Module Replacement, Remove the Memory Module: stap 7, afbeelding 1 van 1
      • Remove the memory module from its connector on the system board.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Johnathan Hammond
46.158 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
7.364 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 975
