Ga door naar hoofdinhoud
Dell Vostro 15 Memory Module Replacement
Wat je nodig hebt
    1. Dell Vostro 15 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
      • Slide the battery release latches until they click into place.
      • Slide the battery out of the battery bay.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro 15 Memory Module Replacement, Hinge Cover: stap 2, afbeelding 1 van 1
      • Open the display all the way so that it rests flat on your work surface.
      • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
      • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
      • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro 15 Memory Module Replacement, KeyBoard: stap 3, afbeelding 1 van 1
      • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
      • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
      • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
      • Rotate the keyboard connector latch upward to release the keyboard cable.
      • Slide the keyboard cable out of the keyboard connector.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Vostro 15 Memory Module Replacement, Memory Module: stap 4, afbeelding 1 van 1
      • Lift the memory module cover But Do Not Remove It.
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Johnathan Hammond
46.158 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.973 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 313
