Ga door naar hoofdinhoud
Dell VRC100-R Touchpad Replacement
Wat je nodig hebt
    1. Dell VRC100-R Touchpad Replacement, Battery: stap 1, afbeelding 1 van 3 Dell VRC100-R Touchpad Replacement, Battery: stap 1, afbeelding 2 van 3 Dell VRC100-R Touchpad Replacement, Battery: stap 1, afbeelding 3 van 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell VRC100-R Touchpad Replacement: stap 2, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 2, afbeelding 2 van 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell VRC100-R Touchpad Replacement, Joystick: stap 3, afbeelding 1 van 3 Dell VRC100-R Touchpad Replacement, Joystick: stap 3, afbeelding 2 van 3 Dell VRC100-R Touchpad Replacement, Joystick: stap 3, afbeelding 3 van 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell VRC100-R Touchpad Replacement: stap 4, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 4, afbeelding 2 van 2
      • Grab the joystick and pull away from the controller to remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell VRC100-R Touchpad Replacement, Touchpad: stap 5, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement, Touchpad: stap 5, afbeelding 2 van 2
      • Remove one 6mm Phillips #0 screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell VRC100-R Touchpad Replacement: stap 6, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 6, afbeelding 2 van 2
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell VRC100-R Touchpad Replacement: stap 7, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 7, afbeelding 2 van 2
      • Turn your controller 90 degrees clockwise and insert a plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell VRC100-R Touchpad Replacement: stap 8, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 8, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    5. Dell VRC100-R Touchpad Replacement: stap 9, afbeelding 1 van 3 Dell VRC100-R Touchpad Replacement: stap 9, afbeelding 2 van 3 Dell VRC100-R Touchpad Replacement: stap 9, afbeelding 3 van 3
      • Use the tip of a plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell VRC100-R Touchpad Replacement: stap 10, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 10, afbeelding 2 van 2
      • Place two fingers on the perimeter of the daughterboard and fold it down along the orange cable.
      Vraag FixBot
      Voeg opmerking toe
    7. Dell VRC100-R Touchpad Replacement: stap 11, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 11, afbeelding 2 van 2
      • Remove two black 6mm Phillips #0 screws.
      Vraag FixBot
      Voeg opmerking toe
    8. Dell VRC100-R Touchpad Replacement: stap 12, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 12, afbeelding 2 van 2
      • Pinch the black ring on the top of your controller and pull toward yourself to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    9. Dell VRC100-R Touchpad Replacement: stap 13, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 13, afbeelding 2 van 2
      • Remove three 3mm Phillips #0 screws.
      Vraag FixBot
      Voeg opmerking toe
    10. Dell VRC100-R Touchpad Replacement: stap 14, afbeelding 1 van 2 Dell VRC100-R Touchpad Replacement: stap 14, afbeelding 2 van 2
      • Insert your finger underneath the black plastic "V" and scoop up to remove it.
      Vraag FixBot
      Voeg opmerking toe
    11. Dell VRC100-R Touchpad Replacement: stap 15, afbeelding 1 van 3 Dell VRC100-R Touchpad Replacement: stap 15, afbeelding 2 van 3 Dell VRC100-R Touchpad Replacement: stap 15, afbeelding 3 van 3
      • Place your thumb on the outer edge of the touchpad on the other side of the controller.
      • Push toward the center of the circle to get your fingernail underneath the touchpad then scoop away from yourself.
      • You can see the detachable black flaps underneath the touchpad along the perimeter.
      • Turn your controller over and remove the touchpad.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Steven Pineda
1.049 Reputatie
3 handleidingen geschreven
Cal Poly, Team S18-G3, Livingston Spring 2018 Lid van Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Leden
15 handleidingen geschreven
1Gids Commentaar
where to get the replacement for touchpad?
Kenneth Alvarez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 37
Altijd: 1,524
