Ga door naar hoofdinhoud
Dell Studio 1555 Keyboard Replacement
Wat je nodig hebt
  1. Dell Studio 1555 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Studio 1555 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell Studio 1555 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell Studio 1555 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Slide the locking switch to the left to release the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Studio 1555 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Gently pull the battery away from the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Studio 1555 Keyboard Replacement: stap 5, afbeelding 1 van 2 Dell Studio 1555 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Studio 1555 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Studio 1555 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Studio 1555 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Dell Studio 1555 Keyboard Replacement: stap 8, afbeelding 1 van 3 Dell Studio 1555 Keyboard Replacement: stap 8, afbeelding 2 van 3 Dell Studio 1555 Keyboard Replacement: stap 8, afbeelding 3 van 3
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
    Vraag FixBot
    Voeg opmerking toe
  9. Dell Studio 1555 Keyboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the keyboard
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Hunter Tuck
214 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 30
Altijd: 1,258
