Inleiding
Use this guide to replace the battery in the Dell Streak 7. This guide will show the steps required to replace the battery in the tablet.
Wat je nodig hebt
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
Using the spudger, disconnect the front camera by lifting up on the connector.
Use the spudger to lift up and detach the cable connecting the battery to the motherboard.
4 andere personen hebben deze handleiding voltooid.
