Ga door naar hoofdinhoud
Dell Precision T3400 Video Card Replacement
  1. Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: stap 1, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Remove the computer's side panel.: stap 1, afbeelding 2 van 2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision T3400 Video Card Replacement, Move the heat-sink assembly lever out of the way: stap 2, afbeelding 1 van 1
    • Push the tab on the blue plastic secure lever and pivot the lever down and away from the assembly
    • Make sure you ground yourself to prevent static discharge
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: stap 3, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Open the video card secure hatch.: stap 3, afbeelding 2 van 2
    • Squeeze the two release tabs together and pivot the secure hatch to the right to open.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Precision T3400 Video Card Replacement, Remove the video card: stap 4, afbeelding 1 van 1
    • Hold the card by its top corner and metal bracket and pull it out of its slot.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Precision T3400 Video Card Replacement, Install the new video card: stap 5, afbeelding 1 van 2 Dell Precision T3400 Video Card Replacement, Install the new video card: stap 5, afbeelding 2 van 2
    • Match the new card’s connectors with the notches in the slot and gently push it into place. The card should click into position when inserted correctly.
    • Close the card door and move the blue plastic secure lever back into place.\
    • Ensure that the card you are replacing the existing card with meets wattage and connectivity requirements. Do not force a card into the slot.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Step 1: Install new card and latch it in place. Step 2: Reinstall the side panel. Step 3: Plug everything back in
8 andere personen hebben deze handleiding voltooid.
Josette Cormier
13 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Leden
14 handleidingen geschreven
1Gids Commentaar
Does it have PCI-E 2.0?
What dimensions the graphics card can have?
Maxime Raguenet - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 62
Altijd: 7,374
