Ga door naar hoofdinhoud
Dell Precision M4700 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision M4700 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Precision M4700 Memory Module Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision M4700 Memory Module Replacement, Base Cover: stap 2, afbeelding 1 van 2 Dell Precision M4700 Memory Module Replacement, Base Cover: stap 2, afbeelding 2 van 2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision M4700 Memory Module Replacement, Keyboard Trim: stap 3, afbeelding 1 van 2 Dell Precision M4700 Memory Module Replacement, Keyboard Trim: stap 3, afbeelding 2 van 2
    • Pry up the keyboard trim starting from the top-inner edge.
    • Pry up the bottom edge of the keyboard trim from the top-inner edge.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Precision M4700 Memory Module Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Precision M4700 Memory Module Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Precision M4700 Memory Module Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Remove the screws that secure the keyboard to the computer.
    • Starting from the bottom of the keyboard, separate the keyboard from the computer and flip the keyboard over.
    • Disconnect the keyboard-data cable from the system board and remove the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Precision M4700 Memory Module Replacement, Memory Module: stap 5, afbeelding 1 van 1
    • Flip Computer To its Back.
    • Pry the retention clips away from the memory module until it pops up. Lift up the memory module and remove it from the computer.
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Precision M4700 Memory Module Replacement: stap 6, afbeelding 1 van 1
    • Flip the Computer To its Top.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Johnathan Hammond
46.149 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.003 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 1,345
