Ga door naar hoofdinhoud
Dell Precision M4400 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision M4400 Memory Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision M4400 Memory Module Replacement, Base Cover: stap 2, afbeelding 1 van 1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision M4400 Memory Module Replacement, Memory Module: stap 3, afbeelding 1 van 1
    • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
    • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Johnathan Hammond
46.158 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.003 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 46
Altijd: 732
