Ga door naar hoofdinhoud
Dell Precision M3800 RAM (Memory) Replacement
Wat je nodig hebt
  1. Dell Precision M3800 RAM (Memory) Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Precision M3800 RAM (Memory) Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision M3800 RAM (Memory) Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision M3800 RAM (Memory) Replacement, Battery: stap 3, afbeelding 1 van 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): stap 4, afbeelding 1 van 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): stap 4, afbeelding 2 van 3 Dell Precision M3800 RAM (Memory) Replacement, RAM (Memory): stap 4, afbeelding 3 van 3
    • Pull the small silver RAM tabs outwards to pop it out of its place in the laptop body.
    • Remove the RAM from the laptop body (it should easily come out after pulling the silver tabs).
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 16
Altijd: 720
