Ga door naar hoofdinhoud
Dell Precision M3800 Fan Replacement
Wat je nodig hebt
  1. Dell Precision M3800 Fan Replacement, Back Cover: stap 1, afbeelding 1 van 2 Dell Precision M3800 Fan Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision M3800 Fan Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision M3800 Fan Replacement, Fan: stap 3, afbeelding 1 van 2 Dell Precision M3800 Fan Replacement, Fan: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Precision M3800 Fan Replacement: stap 4, afbeelding 1 van 3 Dell Precision M3800 Fan Replacement: stap 4, afbeelding 2 van 3 Dell Precision M3800 Fan Replacement: stap 4, afbeelding 3 van 3
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Precision M3800 Fan Replacement: stap 5, afbeelding 1 van 2 Dell Precision M3800 Fan Replacement: stap 5, afbeelding 2 van 2
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 35
Altijd: 1,731
