Ga door naar hoofdinhoud
Dell Precision 7710 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: stap 1, afbeelding 1 van 1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision 7710 Memory Module Replacement, Battery: stap 2, afbeelding 1 van 1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: stap 3, afbeelding 1 van 1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
    Vraag FixBot
    Voeg opmerking toe
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: stap 4, afbeelding 1 van 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: stap 4, afbeelding 2 van 2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
    Vraag FixBot
    Voeg opmerking toe
  5. Dell Precision 7710 Memory Module Replacement: stap 5, afbeelding 1 van 1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
    Vraag FixBot
    Voeg opmerking toe
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: stap 6, afbeelding 1 van 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
    Vraag FixBot
    Voeg opmerking toe
  7. Dell Precision 7710 Memory Module Replacement: stap 7, afbeelding 1 van 1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Johnathan Hammond
46.149 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.003 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 2,380
