Ga door naar hoofdinhoud
Dell Precision 5520 Memory Module Replacement
Wat je nodig hebt
  1. Dell Precision 5520 Memory Module Replacement, Base Cover: stap 1, afbeelding 1 van 2 Dell Precision 5520 Memory Module Replacement, Base Cover: stap 1, afbeelding 2 van 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
    Vraag FixBot
    Voeg opmerking toe
  2. Dell Precision 5520 Memory Module Replacement, Battery: stap 2, afbeelding 1 van 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
    Vraag FixBot
    Voeg opmerking toe
  3. Dell Precision 5520 Memory Module Replacement, Memory Module: stap 3, afbeelding 1 van 1
    • Pry the securing clips away from the memory module until it pops-up [1]. Then, remove the memory module from its connector on the system board [2].
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Johnathan Hammond
46.158 Reputatie
408 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
45 Leden
2.003 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 1,817
