Ga door naar hoofdinhoud
Dell Photo Printer 540 Memory Card Reader Replacement
Wat je nodig hebt
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Case: stap 1, afbeelding 1 van 1
      • Rotate the photo printer so that the bottom of the case faces upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Photo Printer 540 Memory Card Reader Replacement: stap 2, afbeelding 1 van 1
      • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Photo Printer 540 Memory Card Reader Replacement: stap 3, afbeelding 1 van 1
      • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Photo Printer 540 Memory Card Reader Replacement: stap 4, afbeelding 1 van 1
      • Remove the back panel of the case by pulling directly back.
      • Some carefully applied force may be required to remove this part.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Photo Printer 540 Memory Card Reader Replacement: stap 5, afbeelding 1 van 1
      • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell Photo Printer 540 Memory Card Reader Replacement: stap 6, afbeelding 1 van 2 Dell Photo Printer 540 Memory Card Reader Replacement: stap 6, afbeelding 2 van 2
      • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
      • Caution! The side panel is held in by tabs; don't break these.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Cooling Fan: stap 7, afbeelding 1 van 1
      • Carefully remove the inner components of the device by lifting the inner components up and out of the casing.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Photo Printer 540 Memory Card Reader Replacement: stap 8, afbeelding 1 van 1
      • Locate the red and black cable that is connecting the fan to the top of the logic board.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Photo Printer 540 Memory Card Reader Replacement: stap 9, afbeelding 1 van 1
      • Carefully, remove the red and black cable from the logic board by pulling gently in order to isolate the cooling fan from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: stap 10, afbeelding 1 van 3 Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: stap 10, afbeelding 2 van 3 Dell Photo Printer 540 Memory Card Reader Replacement, Mother Board: stap 10, afbeelding 3 van 3
      • Locate the data ribbon that connects the LCD panel to the mother board.
      • Loosen the fasteners next to the ribbon by carefully pushing them away from the white ribbon holder.
      • Once the fasteners are loosened the ribbon should easily slide away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Photo Printer 540 Memory Card Reader Replacement: stap 11, afbeelding 1 van 3 Dell Photo Printer 540 Memory Card Reader Replacement: stap 11, afbeelding 2 van 3 Dell Photo Printer 540 Memory Card Reader Replacement: stap 11, afbeelding 3 van 3
      • Locate the clips with multi-colored wires that connect the motherboard to the printing unit.
      • Disconnect both of them by gently pulling them away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Photo Printer 540 Memory Card Reader Replacement: stap 12, afbeelding 1 van 3 Dell Photo Printer 540 Memory Card Reader Replacement: stap 12, afbeelding 2 van 3 Dell Photo Printer 540 Memory Card Reader Replacement: stap 12, afbeelding 3 van 3
      • Locate the white ribbon that connects the motherboard to the printing feed.
      • Disconnect the ribbon by gently pulling the ribbon away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Dell Photo Printer 540 Memory Card Reader Replacement: stap 13, afbeelding 1 van 2 Dell Photo Printer 540 Memory Card Reader Replacement: stap 13, afbeelding 2 van 2
      • The mother board has changed orientation. Notice the new orientation based on the white data ribbon we removed in the previous step.
      • Locate the black data ribbon that connects the mother board to the printing motors.
      • Disconnect it from the logic board, by gently pulling the wire away from the mother board.
      Vraag FixBot
      Voeg opmerking toe
    5. Dell Photo Printer 540 Memory Card Reader Replacement: stap 14, afbeelding 1 van 1
      • Now unscrew the three screws 7.89mm (counter-clockwise) using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Dell Photo Printer 540 Memory Card Reader Replacement: stap 15, afbeelding 1 van 1
      • Once screws and ribbons are disconnected, you can pull mother board away from the printing unit.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Removal of the Control Panel Motherboard: stap 16, afbeelding 1 van 1
      • Gain access to the bottom of the top case with a thin horizontal control panel motherboard attached to the bottom.
      • Remove the front panel.
      • The dell top casing should now only have two sides.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Photo Printer 540 Memory Card Reader Replacement: stap 17, afbeelding 1 van 2 Dell Photo Printer 540 Memory Card Reader Replacement: stap 17, afbeelding 2 van 2
      • Locate the four 7.85 mm screws attaching the control panel motherboard to the top face casing.
      • Use a Phillips Head #1 screw driver to remove the four highlighted screws.
      • NOTE: Make sure removal of front face plate is completed.
      Vraag FixBot
      Voeg opmerking toe
    3. Dell Photo Printer 540 Memory Card Reader Replacement: stap 18, afbeelding 1 van 1
      • Gently lift the horizontal control panel motherboard and square power switch board.
      • Completely detach the motherboard from the face casing.
      • NOTE: Leave the power switch control attached to the main control panel motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Photo Printer 540 Memory Card Reader Replacement, Memory Card Reader: stap 19, afbeelding 1 van 2 Dell Photo Printer 540 Memory Card Reader Replacement, Memory Card Reader: stap 19, afbeelding 2 van 2
      • Locate the clear data ribbon with a blue tip that connects the memory card reader to the control panel motherboard
      • Disconnect the data ribbon and the memory card reader is now separated.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jonathan Mintz
11 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-7, Forte Spring 2012 Lid van Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 Leden
60 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 1,234
