Ga door naar hoofdinhoud
Dell Optiplex 745 Small Form Factor RAM Replacement
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: stap 1, afbeelding 1 van 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Opening the case: stap 1, afbeelding 2 van 2
      • Pull the tab and the lid will pop up.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Optiplex 745 Small Form Factor RAM Replacement: stap 2, afbeelding 1 van 2 Dell Optiplex 745 Small Form Factor RAM Replacement: stap 2, afbeelding 2 van 2
      • Grab the lid and pull it up and off.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: stap 3, afbeelding 1 van 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Disconnecting the cables: stap 3, afbeelding 2 van 2
      • Pull out both sets of cables from the side of the optical drive.
      • Both cables are plugged into the drive right next to each other.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: stap 4, afbeelding 1 van 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Removing the optical drive: stap 4, afbeelding 2 van 2
      • Pull the tab up holding the optical drive in place.
      • Slide the optical drive out.
      Vraag FixBot
      Voeg opmerking toe
    1. Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: stap 5, afbeelding 1 van 2 Dell Optiplex 745 Small Form Factor RAM Replacement, Unlocking the RAM stick from the motherboard: stap 5, afbeelding 2 van 2
      • Press down on the white tabs on both sides of the RAM stick until the RAM stick pops up.
      Vraag FixBot
      Voeg opmerking toe
    2. Dell Optiplex 745 Small Form Factor RAM Replacement, Lifting the RAM stick out of the case: stap 6, afbeelding 1 van 1
      • Gently lift the RAM stick up and out of the case.
      • When inserting a RAM stick, press firmly down into the slot until the white tabs lock into both sides of the stick.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Brandon Cooper
486 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-10, Forte Fall 2014 Lid van Cal Poly, Team 13-10, Forte Fall 2014
CPSU-FORTE-F14S13G10
6 Leden
30 handleidingen geschreven
1Gids Commentaar
Dell master. I'm going to be the best repair pro on this side of the south side.
fixitbrosmsus - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 2,198
