Wat je nodig hebt
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
To close the case, simply press it closed until you hear the tabs click into place.
18 andere personen hebben deze handleiding voltooid.
1Gids Commentaar
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
cool de faires des sites comme ca :)
baptiste Prando - Antwoord
mm pas mon fere
Thoma Delanou -
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - Antwoord
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Elvis 1357 - Antwoord
Also, want to add another HD....but, there are no cables at all?
ca pue la merde sah
Thoma Delanou - Antwoord
